주요 콘텐츠로 건너뛰기
BlackBerry World Edition 8830 Motherboard Replacement
필요한 것
  1. BlackBerry World Edition 8830 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before beginning this installation, make sure phone is powered off .
    • Turn phone over to the backside.
    • Press down on the lower portion of the back cover.
    • Slide the lower portion down to remove the cover and reveal the battery.
  2. BlackBerry World Edition 8830 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery from the phone.
  3. BlackBerry World Edition 8830 Motherboard Replacement, Front and Back Casing: 3 단계, 이미지 2개 중 1개 BlackBerry World Edition 8830 Motherboard Replacement, Front and Back Casing: 3 단계, 이미지 2개 중 2개
    • Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
  4. BlackBerry World Edition 8830 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
  5. BlackBerry World Edition 8830 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 BlackBerry World Edition 8830 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the back casing using the Plastic Opening Tool
    • Once the back casing is removed the top two buttons are likely to pop out.
  6. BlackBerry World Edition 8830 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Locate the two 9.2mm screws on the upper inside casing
    • Remove them using the T4 Torx Screwdriver
    • Slide off the front casing once the screws are removed.
    • Trackball will fall out once the casing is removed.
  7. BlackBerry World Edition 8830 Motherboard Replacement, LCD Screen: 7 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Motherboard Replacement, LCD Screen: 7 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Motherboard Replacement, LCD Screen: 7 단계, 이미지 3개 중 3개
    • Disconnect the tab attached to the interior casing from the LCD Screen by gently pulling the tab up and away from the phone.
    • Use the Plastic Opening Tool to pry the LCD Screen out.
  8. BlackBerry World Edition 8830 Motherboard Replacement, Motherboard: 8 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Motherboard Replacement, Motherboard: 8 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Motherboard Replacement, Motherboard: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Grab and remove the middle bar located on the bottom of the phone.
    • Once the bar is removed, a small wire will be revealed. Remove the wire using your tweezers.
    • There are two places that wire is clipped in. To disconnect the wire, gently pull up on the wire until it pops off of the connector.
  9. BlackBerry World Edition 8830 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Once the wire is removed, locate the six clips located along the phones edges. There are two on each side, and two on the top.
    • Carefully unhook the clips by hand or with the plastic opening tool to allow the back cover to come off.
  10. BlackBerry World Edition 8830 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 BlackBerry World Edition 8830 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • With the motherboard revealed, slowly lift it off of the casing.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Martha de Maria y Campos
회원 가입일: 04/12/12
121 평판
안내서 5개를 작성함
Cal Poly, Team 17-27, Amido Spring 2012 Cal Poly, Team 17-27, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G27
4 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,628
