주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BlackBerry World Edition 8830 Trackball Replacement
필요한 것
  1. BlackBerry World Edition 8830 Trackball Replacement, Trackball: 1 단계, 이미지 3개 중 1개 BlackBerry World Edition 8830 Trackball Replacement, Trackball: 1 단계, 이미지 3개 중 2개 BlackBerry World Edition 8830 Trackball Replacement, Trackball: 1 단계, 이미지 3개 중 3개
    • Make sure the phone is powered off before removing the trackball.
    • Gently use the Small Flathead Screwdriver or plastic opening tool to go under the chrome ring surrounding the trackball.
    • Pry the chrome ring upwards with the tool until it begins to lift up.
    • Once it begins to lift up, gently remove the chrome ring from around the trackball.
    • When re-assembling the phone, be sure to orient the chrome ring so that the missing tab is at the top.
  2. BlackBerry World Edition 8830 Trackball Replacement: 2 단계, 이미지 2개 중 1개 BlackBerry World Edition 8830 Trackball Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • After removing the chrome ring, slowly lift up the remaining piece with tweezers.
    • Slowly remove the small plastic bottom using the Plastic Opener tool. Be careful not to bend the metal frame when removing the bottom plastic piece.
    • Using your hands, remove the white plastic piece, revealing the small metal frame, the scroll wheels, and the trackball.
  3. BlackBerry World Edition 8830 Trackball Replacement: 3 단계, 이미지 1개 중 1개
    • Slowly remove the trackball, being cautious not to scratch the ball or the scroll wheels.
    • Using a soft cloth, carefully remove any dust around the scroll wheels or the trackball itself.
    • While the trackball is removed, you may clean the sensor in the hole where the trackball is usually located.
결론
작성자
5다른 기여자 명과 함께
tbace
회원 가입일: 04/18/12
28 평판
안내서 2개를 작성함
Cal Poly, Team 17-27, Amido Spring 2012 Cal Poly, Team 17-27, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G27
4 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 27
지난 30일: 84
전체 시간: 1,471
