주요 콘텐츠로 건너뛰기
BlackBerry Z10 Battery Replacement
  1. BlackBerry Z10 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the phone over so that the back cover faces up.
    • Locate the groove at the bottom center of the phone.
    • Press the groove with your thumb to release the edge of the case from the phone.
  2. BlackBerry Z10 Battery Replacement: 2 단계, 이미지 1/2 BlackBerry Z10 Battery Replacement: 2 단계, 이미지 2/2
    • Use your thumb and index finger to carefully open the sides of the phone.
    • Start from the bottom and work your fingers up along the sides of the phone until the back cover is completely separated from the body of the phone.
  3. BlackBerry Z10 Battery Replacement: 3 단계, 이미지 1/3 BlackBerry Z10 Battery Replacement: 3 단계, 이미지 2/3 BlackBerry Z10 Battery Replacement: 3 단계, 이미지 3/3
    • Lift the bottom corner of the battery with your fingers.
    • Remove the battery from the body of the phone.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Emie Lou Cruz
회원 가입일: 09/08/14
1,084 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 1-2, Bruce Fall 2014 CSU Fullerton, Team 1-2, Bruce Fall 2014 회원
CSUF-BRUCE-F14S1G2
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Battery 🔋 full but in one minute to lower
And power off
Zezo1901 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 4,467
