주요 콘텐츠로 건너뛰기
BlackBerry Z10 Motherboard Assembly Replacement
필요한 것
  1. BlackBerry Z10 Motherboard Assembly Replacement, Motherboard Assembly: 1 단계, 이미지 1/2 BlackBerry Z10 Motherboard Assembly Replacement, Motherboard Assembly: 1 단계, 이미지 2/2
    • This is the easiest repair I've completed yet.
  2. BlackBerry Z10 Motherboard Assembly Replacement: 2 단계, 이미지 1/3 BlackBerry Z10 Motherboard Assembly Replacement: 2 단계, 이미지 2/3 BlackBerry Z10 Motherboard Assembly Replacement: 2 단계, 이미지 3/3
    • The rear panel pops off easily. Grab the opening at the bottom and work your way around.
  3. BlackBerry Z10 Motherboard Assembly Replacement: 3 단계, 이미지 1/2 BlackBerry Z10 Motherboard Assembly Replacement: 3 단계, 이미지 2/2
    • There is NO adhesive on this device. NO ADHESIVE!!
  4. BlackBerry Z10 Motherboard Assembly Replacement: 4 단계, 이미지 1/3 BlackBerry Z10 Motherboard Assembly Replacement: 4 단계, 이미지 2/3 BlackBerry Z10 Motherboard Assembly Replacement: 4 단계, 이미지 3/3
    • There's about 7 screws here. Remove the black circle sticker to uncover a hidden screw.
  5. BlackBerry Z10 Motherboard Assembly Replacement: 5 단계, 이미지 1/3 BlackBerry Z10 Motherboard Assembly Replacement: 5 단계, 이미지 2/3 BlackBerry Z10 Motherboard Assembly Replacement: 5 단계, 이미지 3/3
    • Disconnect the logic board connector near the top and left side.
    • Underneath the connector on the left side, there's two other connectors. Disconnect those.
    • Remove the logic board and viola, you're done! Easiest repair in life!! To reassemble follow this guide in reverse. Happy repairing!
결론
다른 21명이 해당 안내서를 완성하였습니다.
Daniel Edwards
회원 가입일: 09/21/10
718 평판
안내서 1개 작성함
댓글 2개
For what is the second Screwdriver and what size is the right on?
Stefan Schenk - 답글
Will changing the motherboard assembly change my imei. I am wondering if I need to check the imei of the new motherboard to make sure it isn’t from a flag phone before install it.
phnark - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 17,186
