소개
To remove the rear camera, you will need tools to open up the phone as well as to remove the motherboard.
필요한 것
Turn the phone over so that the back cover faces up.
Locate the groove at the bottom center of the phone.
Press the groove with your thumb to release the edge of the case from the phone.
Now that all of the ribbon cables have been disconnected, carefully lift the motherboard from its housing with your thumb and index finger. Start lifting the motherboard from the bottom and work your way to the top. Hold down the phone with your other hand so you have a better grip on the device. Once removed, turn the motherboard over.
To disconnect the rear camera from the motherboard, carefully lift up the gold-plated connector. It is located just below the rear camera.
Then, hold and remove the rear camera using your thumb and index finger. It should detach along with the connector. Finally, set the rear camera aside.
다른 6명이 해당 안내서를 완성하였습니다.
