주요 콘텐츠로 건너뛰기
BlackBerry Z30 Middle Frame Replacement
필요한 것
  1. BlackBerry Z30 Middle Frame Replacement, Battery cover: 1 단계, 이미지 1/1
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Middle Frame Replacement, Remove SIM and Media Card: 2 단계, 이미지 1/1
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Middle Frame Replacement, Unscrewing the LCD panel: 3 단계, 이미지 1/3 BlackBerry Z30 Middle Frame Replacement, Unscrewing the LCD panel: 3 단계, 이미지 2/3 BlackBerry Z30 Middle Frame Replacement, Unscrewing the LCD panel: 3 단계, 이미지 3/3
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Middle Frame Replacement, Separate the LCD from the Frame: 4 단계, 이미지 1/2 BlackBerry Z30 Middle Frame Replacement, Separate the LCD from the Frame: 4 단계, 이미지 2/2
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Middle Frame Replacement, Remove the LCD: 5 단계, 이미지 1/2 BlackBerry Z30 Middle Frame Replacement, Remove the LCD: 5 단계, 이미지 2/2
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Middle Frame Replacement, LCD Panel removal: 6 단계, 이미지 1/1
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Middle Frame Replacement, Untie the System board: 7 단계, 이미지 1/1
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Middle Frame Replacement, Untie the System board Part 2: 8 단계, 이미지 1/1
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Middle Frame Replacement, Untie the system board Part 3: 9 단계, 이미지 1/1
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Middle Frame Replacement, System board removal: 10 단계, 이미지 1/1
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
  11. BlackBerry Z30 Middle Frame Replacement, Remove the Rear Camera: 11 단계, 이미지 1/2 BlackBerry Z30 Middle Frame Replacement, Remove the Rear Camera: 11 단계, 이미지 2/2
    • Use a pair of pliers to remove the rear facing camera
  12. BlackBerry Z30 Middle Frame Replacement, Remove the Battery: 12 단계, 이미지 1/3 BlackBerry Z30 Middle Frame Replacement, Remove the Battery: 12 단계, 이미지 2/3 BlackBerry Z30 Middle Frame Replacement, Remove the Battery: 12 단계, 이미지 3/3
    • If this is the original battery, it might be hold down by VERY strong adhesive on the top, middle and bottom part. Be careful not to damage the battery
    • As pointed in the comments, be careful about the NFC membrane when removing the battery. Use heat to loosen the glue.
  13. BlackBerry Z30 Middle Frame Replacement, Replace the Middle Frame: 13 단계, 이미지 1/1
    • Re-Assemble the unit using the new middle frame.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Hans
회원 가입일: 10/20/14
1,920 평판
안내서 6개 작성하였습니다
Mero IT Services Mero IT Services 회원
Business
1 회원
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 3,818
