소개
This guide details how to remove and replace the phone's LCD screen if it has broken.
부품
부품은 필요하지 않습니다.
  1. With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Remove the battery by pushing against it from the right and then pulling towards you.
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  6. Use a plastic opening tool or your fingernails to remove the plastic backing. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  7. Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  8. The black battery casing and logic board can now be separated for the following steps.
    • The black battery casing and logic board can now be separated for the following steps.
  9. The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • Warning: Some of the phones have an adhesive between the silver part and the battery housing, so it could stick to the black piece you just removed.
  10. Use a plastic opening tool to lift up the two black clips indicated in the picture. Hold on to the keyboard while unfastening the clips.
    • Use a plastic opening tool to lift up the two black clips indicated in the picture.
    • Hold on to the keyboard while unfastening the clips.
    • The keyboard will detach once the clips are unfastened.
  11. With the screen facing you, you will be able to see a small grey plastic clip.
    • With the screen facing you, you will be able to see a small grey plastic clip.
    • Use a plastic opening tool to unfasten the clip as shown.
  12. Flip the logic board over to the other side. Use a plastic opening tool unclip the top two clips shown in red, and then the bottom two clips. This releases the screen.
    • Flip the logic board over to the other side.
    • Use a plastic opening tool unclip the top two clips shown in red, and then the bottom two clips. This releases the screen.
    • Flip logic board over and remove screen.
    • Make sure to hold the screen, it could fall after being unclipped.
  13. NOTE: If you are not replacing the LCD screen, move on to the next step.
    • NOTE: If you are not replacing the LCD screen, move on to the next step.
    • After removing the original screen, keep the logic board facing you the way it was.
    • Take the new screen and slip the flexible piece of connecting circuitry under the grey plastic flap that you pried up in step 10.
    • Handle the screen carefully as it is fragile.
    • Push it gently but firmly until it does not move any further to the left, then close the grey flap.
    • After this, the screen can be pushed down and clicked back into place.
    • To reassemble the phone, reverse instructions.
결승점
CeeJay
회원 가입일: 2009년 10월 28일
19 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-17, Regan Fall 2009 Cal Poly, Team 9-17, Regan Fall 2009 회원
CPSU-REGAN-F09S9G17
4 회원들
안내서 7개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,031
