주요 콘텐츠로 건너뛰기
Blackberry 7105t Second Disassembly Replacement
필요한 것
  1. Blackberry 7105t Second Disassembly Replacement, Blackberry 7105t Disassembly: 1 단계, 이미지 1/1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Second Disassembly Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Second Disassembly Replacement: 3 단계, 이미지 1/1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Second Disassembly Replacement: 4 단계, 이미지 1/1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Second Disassembly Replacement: 5 단계, 이미지 1/3 Blackberry 7105t Second Disassembly Replacement: 5 단계, 이미지 2/3 Blackberry 7105t Second Disassembly Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Second Disassembly Replacement: 6 단계, 이미지 1/1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Second Disassembly Replacement: 7 단계, 이미지 1/1
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t Second Disassembly Replacement, Second Disassembly: 8 단계, 이미지 1/1
    • The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • Warning: Some of the phones have an adhesive between the silver part and the battery housing, so it could stick to the black piece you just removed.
결론
CeeJay
회원 가입일: 10/28/09
19 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-17, Regan Fall 2009 Cal Poly, Team 9-17, Regan Fall 2009 회원
CPSU-REGAN-F09S9G17
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 13
전체 시간: 1,296
