주요 콘텐츠로 건너뛰기
Blackberry 7105t Speaker Replacement
필요한 것
  1. Blackberry 7105t Speaker Replacement, Blackberry 7105t Disassembly: 1 단계, 이미지 1/1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Speaker Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Speaker Replacement: 5 단계, 이미지 1/3 Blackberry 7105t Speaker Replacement: 5 단계, 이미지 2/3 Blackberry 7105t Speaker Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Speaker Replacement: 6 단계, 이미지 1/1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Speaker Replacement: 7 단계, 이미지 1/1
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t Speaker Replacement, Speaker: 8 단계, 이미지 1/2 Blackberry 7105t Speaker Replacement, Speaker: 8 단계, 이미지 2/2
    • With the speaker facing towards you, use a spudger to unfasten the three clips indicated in the picture.
    • Place the three clips in plastic bag and set aside.
    • Once clips are removed, you will have full access to remove the speaker.
결론
CeeJay
회원 가입일: 10/28/09
19 평판
안내서 5개 작성하였습니다
Cal Poly, Team 9-17, Regan Fall 2009 Cal Poly, Team 9-17, Regan Fall 2009 회원
CPSU-REGAN-F09S9G17
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 1,191
