소개
This guide outlines how to remove the battery connector from the device.
부품
부품은 필요하지 않습니다.
  1. With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Remove the battery by pushing against it from the right and then pulling towards you.
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  6. Use a plastic opening tool or your fingernails to remove the plastic backing. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  7. Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  8. The black battery casing and logic board can now be separated for the following steps.
    • The black battery casing and logic board can now be separated for the following steps.
  9. With the speaker facing you, place your fingers on the gold battery connector.
    • With the speaker facing you, place your fingers on the gold battery connector.
    • Pull upwards and release the battery connector from the black body piece.
결론
kelogan
회원 가입일: 2009년 11월 04일
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-17, Regan Fall 2009 Cal Poly, Team 9-17, Regan Fall 2009 회원
CPSU-REGAN-F09S9G17
4 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 3,172
