소개
For removing and replacing the Blackberry 7520 battery, follow this guide.
도구
도구는 필요하지 않습니다.
부품
부품은 필요하지 않습니다.
Turn the phone upside down.
  • Turn the phone upside down.
  • Push down on the black button on the back of the phone to slide the rear panel off.
  • The battery should be visible now.
댓글 쓰기
Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Gently smack the phone against your hand to dislodge the battery.
댓글 쓰기
  • To install the battery turn the phone on its back.
  • Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle)
  • Once the battery is lined up push the battery in and down until it is locked in.
댓글 쓰기
  • Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone.
  • Push the panel inwards then down until it locks in.
  • Once the panel is in you have successfully changed your battery!
댓글 쓰기
결승점
Nathan
회원 가입일: 2010년 01월 18일
31 평판
안내서 7개 작성하였습니다
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010 회원
CPSU-FORTE-W10S5G7
5 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,429
