주요 콘텐츠로 건너뛰기
Blackberry 7520 Motherboard Replacement
필요한 것
  1. Blackberry 7520 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Blackberry 7520 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 Motherboard Replacement: 2 단계, 이미지 1/3 Blackberry 7520 Motherboard Replacement: 2 단계, 이미지 2/3 Blackberry 7520 Motherboard Replacement: 2 단계, 이미지 3/3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 Blackberry 7520 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Blackberry 7520 Motherboard Replacement: 4 단계, 이미지 1/2 Blackberry 7520 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Blackberry 7520 Motherboard Replacement: 5 단계, 이미지 1/1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 Motherboard Replacement: 6 단계, 이미지 1/2 Blackberry 7520 Motherboard Replacement: 6 단계, 이미지 2/2
    • Slide the rear panel forward to reveal the motherboard.
  7. Blackberry 7520 Motherboard Replacement: 7 단계, 이미지 1/2 Blackberry 7520 Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the indicated screws using a T6 Torx screwdriver.
  8. Blackberry 7520 Motherboard Replacement: 8 단계, 이미지 1/2 Blackberry 7520 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  9. Blackberry 7520 Motherboard Replacement: 9 단계, 이미지 1/2 Blackberry 7520 Motherboard Replacement: 9 단계, 이미지 2/2
    • Pull the metal plate away from the front panel of the cell phone.
  10. Blackberry 7520 Motherboard Replacement: 10 단계, 이미지 1/1
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
결론
Nathan
회원 가입일: 01/18/10
31 평판
안내서 6개 작성하였습니다
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010 회원
CPSU-FORTE-W10S5G7
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 3,583
