주요 콘텐츠로 건너뛰기
Blackberry 8110 Keyboard Replacement
필요한 것
  1. Blackberry 8110 Keyboard Replacement, Removing the back cover.: 1 단계, 이미지 1/2 Blackberry 8110 Keyboard Replacement, Removing the back cover.: 1 단계, 이미지 2/2
    • Turn the phone over so that the screen is facing the table. Locate the chrome release button and push it in to unclip the battery cover.
  2. Blackberry 8110 Keyboard Replacement, Removing the screws.: 2 단계, 이미지 1/2 Blackberry 8110 Keyboard Replacement, Removing the screws.: 2 단계, 이미지 2/2
    • Now that the battery cover has been removed, locate the two 7.5mm Torx #T6 screws at the top of the phone. Remove these by turning counter-clockwise with your T6 screwdriver.
  3. Blackberry 8110 Keyboard Replacement, Removing the bottom cover.: 3 단계, 이미지 1/2 Blackberry 8110 Keyboard Replacement, Removing the bottom cover.: 3 단계, 이미지 2/2
    • Now that the two screws at the top have been removed, take your spudger and locate the two gaps to the left and right of the button that releases the battery cover.
    • With your spudger, carefully wedge it into the gap and pry downwards to release the bottom cover.
  4. Blackberry 8110 Keyboard Replacement, Removing the screws on the front side.: 4 단계, 이미지 1/2 Blackberry 8110 Keyboard Replacement, Removing the screws on the front side.: 4 단계, 이미지 2/2
    • Turn the phone over so that the screen is facing up. With the bottom cover off, you will be able to locate two 7.5mm Torx #T6 screws in each corner below the keyboard. Carefully remove these.
  5. Blackberry 8110 Keyboard Replacement, Taking off the side panels.: 5 단계, 이미지 1/3 Blackberry 8110 Keyboard Replacement, Taking off the side panels.: 5 단계, 이미지 2/3 Blackberry 8110 Keyboard Replacement, Taking off the side panels.: 5 단계, 이미지 3/3
    • Now that the screws on the front have been removed, take your spudger and wedge it between the trim on the side of the phone, and the phone itself. Carefully pry the trim away from the phone.
  6. Blackberry 8110 Keyboard Replacement, Removing the back panel: 6 단계, 이미지 1/2 Blackberry 8110 Keyboard Replacement, Removing the back panel: 6 단계, 이미지 2/2
    • You are now ready to remove the back panel. In order to do this, locate the two clips on each side of the phone (underneath the trim that you just removed).
    • Once you locate these clips (four in total, two on each side), you should be able to unclip them with your fingers.
    • Be gentle as to not break the clips in doing so.
  7. Blackberry 8110 Keyboard Replacement, Removing the front panel.: 7 단계, 이미지 1/2 Blackberry 8110 Keyboard Replacement, Removing the front panel.: 7 단계, 이미지 2/2
    • The front panel is now ready to be removed from the rest of the phone. To do this, just pry the front part (with the keyboard and screen) away from the logic board of the phone with your fingers.
  8. Blackberry 8110 Keyboard Replacement, Replacing the keyboard.: 8 단계, 이미지 1/2 Blackberry 8110 Keyboard Replacement, Replacing the keyboard.: 8 단계, 이미지 2/2
    • You are now ready to replace the keyboard! To do this, hold the front screen with the keyboard, and it should fall right out if you push it through the front screen.
    • To install the new keyboard, place it on top of the front screen and seat it in place with the grooves.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Yaqoub Alshawaf
회원 가입일: 09/25/14
201 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-2, Brown Fall 2014 USF Tampa, Team 1-2, Brown Fall 2014 회원
USFT-BROWN-F14S1G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 259
