주요 콘텐츠로 건너뛰기
Blackberry 8700c Battery Replacement
  1. Blackberry 8700c Battery Replacement, Battery: 1 단계, 이미지 1/3 Blackberry 8700c Battery Replacement, Battery: 1 단계, 이미지 2/3 Blackberry 8700c Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the back cover by pushing the button near the bottom of the phone and sliding the cover off.
  2. Blackberry 8700c Battery Replacement: 2 단계, 이미지 1/2 Blackberry 8700c Battery Replacement: 2 단계, 이미지 2/2
    • Using your fingernail, remove the battery by pulling on the notch on the top-right of the battery.
    • If you are not installing a new battery, move on to the next step. If you are installing a new battery, read on.
    • Install the new battery by first placing the bottom end of the battery in the phone and then pushing the battery into place.
결론
To reassemble your Blackberry 8700c, follow these instructions in reverse order.
k3nt
회원 가입일: 10/28/09
42 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009 회원
CPSU-MANESS-F09S18G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 2,819
