주요 콘텐츠로 건너뛰기
Blackberry Bold 9000 LCD Screen Replacement
필요한 것
  1. Blackberry Bold 9000 LCD Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 LCD Screen Replacement: 3 단계, 이미지 1/1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 LCD Screen Replacement, Rear Case: 4 단계, 이미지 1/1
    • Remove the SIM card.
  5. Blackberry Bold 9000 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 LCD Screen Replacement: 6 단계, 이미지 1/1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 LCD Screen Replacement, LCD Screen: 7 단계, 이미지 1/1
    • With the same plastic opening tool, lift the motherboard up and out.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 LCD Screen Replacement: 8 단계, 이미지 1/1
    • Using a spudger, lift the ribbon band in the upper right-hand corner up and away from the motherboard assembly until it disconnects.
  9. Blackberry Bold 9000 LCD Screen Replacement: 9 단계, 이미지 1/1
    • Turn the motherboard assembly over.
    • Starting at the lower corners of the screen, begin to lift the screen away from the motherboard using the spudger.
    • Do this step very slowly to avoid breaking the screen or the motherboard. The backing will eventually separate.
    • Remove the plastic bit that hides the speaker grill - it is stuck with double-sided tape.
    • With a thin blade/pin, ease the speaker grill and the metal plate away from the old lcd screen.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Kelly
회원 가입일: 01/18/12
566 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-17, Maness Winter 2012 Cal Poly, Team 8-17, Maness Winter 2012 회원
CPSU-MANESS-W12S8G17
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 7,517
