주요 콘텐츠로 건너뛰기
Blackberry Bold 9000 Trackball Replacement
필요한 것
  1. Blackberry Bold 9000 Trackball Replacement, Battery: 1 단계, 이미지 1/1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Trackball Replacement: 2 단계, 이미지 1/1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Trackball Replacement: 3 단계, 이미지 1/1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Trackball Replacement, Rear Case: 4 단계, 이미지 1/1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Trackball Replacement: 5 단계, 이미지 1/1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Trackball Replacement: 6 단계, 이미지 1/1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Trackball Replacement, Trackball: 7 단계, 이미지 1/1
    • Using the same plastic opening tool, lift out the motherboard assembly.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Trackball Replacement: 8 단계, 이미지 1/1
    • Using a spudger, pry the top of the metal casing off. There are two pins holding it in place; it should pop off easily.
    • Repeat to the bottom.
    • This step requires pristine dexterity. Try to find a friend with smaller fingers if necessary.
  9. Blackberry Bold 9000 Trackball Replacement: 9 단계, 이미지 1/1
    • Lift the trackball out of its socket.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Kelly
회원 가입일: 01/18/12
566 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-17, Maness Winter 2012 Cal Poly, Team 8-17, Maness Winter 2012 회원
CPSU-MANESS-W12S8G17
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 16
전체 시간: 11,182
