주요 콘텐츠로 건너뛰기
Blackberry Bold 9000 Volume Toggle Replacement
필요한 것
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: 1 단계, 이미지 1/1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Volume Toggle Replacement: 2 단계, 이미지 1/1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Volume Toggle Replacement: 3 단계, 이미지 1/1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: 4 단계, 이미지 1/1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Volume Toggle Replacement: 5 단계, 이미지 1/1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Volume Toggle Replacement: 6 단계, 이미지 1/1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: 7 단계, 이미지 1/1
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Volume Toggle Replacement: 8 단계, 이미지 1/1
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Blackberry Bold 9000 Volume Toggle Replacement: 9 단계, 이미지 1/1
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kelly
회원 가입일: 01/18/12
566 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-17, Maness Winter 2012 Cal Poly, Team 8-17, Maness Winter 2012 회원
CPSU-MANESS-W12S8G17
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 2,445
