주요 콘텐츠로 건너뛰기
Blackberry Bold 9650 Back Chassis Replacement
필요한 것
  1. Blackberry Bold 9650 Back Chassis Replacement, Battery: 1 단계, 이미지 2개 중 1개 Blackberry Bold 9650 Back Chassis Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Back Chassis Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Back Chassis Replacement, SIM Card: 3 단계, 이미지 1개 중 1개
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Back Chassis Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Back Chassis Replacement, Back Chassis: 5 단계, 이미지 1개 중 1개
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Back Chassis Replacement: 6 단계, 이미지 1개 중 1개
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Back Chassis Replacement: 7 단계, 이미지 1개 중 1개
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Back Chassis Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Ryan
회원 가입일: 03/12/12
696 평판
안내서 11개를 작성함
Clemson, Team 2-5, Benson Spring 2012 Clemson, Team 2-5, Benson Spring 2012 회원
CLEM-BENSON-S12S2G5
2 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 3,218
