주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Turn the device upside down. Using your finger, slide the silver cover release button towards the top of the device.
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Using your fingernails, lift the sides of the battery.
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Orient the device so that the screen is facing the ground.
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Gently pull out the SIM card.
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
    • Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
  6. Orient the device so that the screen is facing you.
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
    • Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
  8. Remove the back chassis by gently pulling the chassis back and forth.
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  10. Using your fingers, carefully lift and remove the mother board.
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  11. Using a pair of tweezers, remove the three ribbon connectors.
    • Using a pair of tweezers, remove the three ribbon connectors.
  12. Remove the mother board by lifting the board upward.
    • Remove the mother board by lifting the board upward.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan
회원 가입일: 2012년 03월 12일
642 평판
안내서 11개 작성하였습니다
Clemson, Team 2-5, Benson Spring 2012 Clemson, Team 2-5, Benson Spring 2012 회원
CLEM-BENSON-S12S2G5
2 회원들
안내서 11개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 3,668
