이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Turn the device upside down.
Using your finger, slide the silver cover release button towards the top of the device.
Lift and remove the back cover.
Orient the device so that the screen is facing the ground.
Using your finger, gently lift the top of the SIM card.
Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
Orient the device so the screen is facing the ground and the top of phone is facing you.
Using a pair of tweezers, lift and remove the following:
The two round connectors on the top of the mother board.
The flat connector in the lower corner of the mother board.
다른 한 분이 해당 안내서를 완성하였습니다.
