주요 콘텐츠로 건너뛰기
Blackberry Bold 9900 Keyboard Replacement
필요한 것
  1. Blackberry Bold 9900 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Keyboard Replacement: 2 단계, 이미지 1/1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Keyboard Replacement, MicroSD card: 3 단계, 이미지 1/2 Blackberry Bold 9900 Keyboard Replacement, MicroSD card: 3 단계, 이미지 2/2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/2 Blackberry Bold 9900 Keyboard Replacement, Keyboard: 4 단계, 이미지 2/2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  5. Blackberry Bold 9900 Keyboard Replacement: 5 단계, 이미지 1/2 Blackberry Bold 9900 Keyboard Replacement: 5 단계, 이미지 2/2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  6. Blackberry Bold 9900 Keyboard Replacement: 6 단계, 이미지 1/1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  7. Blackberry Bold 9900 Keyboard Replacement: 7 단계, 이미지 1/2 Blackberry Bold 9900 Keyboard Replacement: 7 단계, 이미지 2/2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Velasquez
회원 가입일: 01/30/18
214 평판
안내서 2개 작성하였습니다
Baylor, Team S1-G4, Johnson Spring 2018 Baylor, Team S1-G4, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 1,511
