주요 콘텐츠로 건너뛰기
Blackberry Bold 9900 Memory Card Replacement
  1. Blackberry Bold 9900 Memory Card Replacement, Battery: 1 단계, 이미지 1/1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Memory Card Replacement: 2 단계, 이미지 1/1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Memory Card Replacement, MicroSD card: 3 단계, 이미지 1/2 Blackberry Bold 9900 Memory Card Replacement, MicroSD card: 3 단계, 이미지 2/2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Memory Card Replacement, Mini-SIM removal: 4 단계, 이미지 1/1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sowmika
회원 가입일: 01/30/18
253 평판
안내서 2개 작성하였습니다
Baylor, Team S1-G4, Johnson Spring 2018 Baylor, Team S1-G4, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 910
