주요 콘텐츠로 건너뛰기
Blackberry Classic digitizer Replacement
필요한 것
  1. Blackberry Classic  digitizer Replacement, Digitizer assembly: 1 단계, 이미지 1/1
    • Start by removing the back cover.
    • It's glued on the top and at the bottom. Use an isesamo and gentle force to remove it
  2. Blackberry Classic  digitizer Replacement: 2 단계, 이미지 1/1
    • Like many other blackberry models, lift out the small plastic edge at the bottom of the keyboard
    • This will reveal two torx screws to remove
  3. Blackberry Classic  digitizer Replacement: 3 단계, 이미지 1/1
    • Turn the blackberry around and remove all torx screws
    • Separate the battery screws as they are different
    • Watch out for the 00 Philips screw on the top left corner
    • Remove the plastic mid-frame
  4. Blackberry Classic  digitizer Replacement: 4 단계, 이미지 1/1
    • The battery is held firmly by glue (or space putty?)
    • That 4$ card proved its utility
    • Be careful when removing the adhesive not to pry the small connectors at the base of the board.
  5. Blackberry Classic  digitizer Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • The board is clipped and lightly glued. Use tweezers to lift the retention clips under the board to release it.
  6. Blackberry Classic  digitizer Replacement: 6 단계, 이미지 1/1
    • Remove the micro usb connector, the audio jack and the 3 ph000 screws on the board.
    • This will allow you to push out the metal mid-frame
  7. Blackberry Classic  digitizer Replacement: 7 단계, 이미지 1/1
    • Once screws are all out, gently lift the broken digitizer. Make sure to lift between the display assembly and the black border.
    • Remove any remaining shattered glass from the display frame before reassembling.
    • Reassemble in reverse order
결론
다른 23명이 해당 안내서를 완성하였습니다.
coutureg
회원 가입일: 07/19/12
885 평판
안내서 1개 작성함
Techno-sos Techno-sos 회원
Business
1 회원
안내서 2개 작성하였습니다
댓글 8개
If I’m just switching boards, is it even necessary to remove the battery? Can’t I just switch the boards with the batteries still attached to their respective boards? I just don’t see the point of removing the battery unless you are replacing it.
gary - 답글
If you are replacing the board and the battery, and can reach the retention clips under the board to lift the board out of the case, I guess it could be possible to replace both parts without separating them.
coutureg -
So I can confirm that you do not need to remove the battery to switch the boards. You can leave it stuck to the board.
https://imgur.com/a/FtY09en
gary - 답글
Interesting, thanks for the update ! Cheers !
coutureg -
You are welcome! Thanks for the great writeup coutureg
gary - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 14
30일 전: 55
전체 시간: 15,641
