주요 콘텐츠로 건너뛰기
Blackberry Curve 8320 Front Panel Replacement
필요한 것
  1. Blackberry Curve 8320 Front Panel Replacement, Battery: 1 단계, 이미지 1/2 Blackberry Curve 8320 Front Panel Replacement, Battery: 1 단계, 이미지 2/2
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Front Panel Replacement: 2 단계, 이미지 1/1
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Front Panel Replacement, Front Panel: 3 단계, 이미지 1/3 Blackberry Curve 8320 Front Panel Replacement, Front Panel: 3 단계, 이미지 2/3 Blackberry Curve 8320 Front Panel Replacement, Front Panel: 3 단계, 이미지 3/3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Front Panel Replacement: 4 단계, 이미지 1/2 Blackberry Curve 8320 Front Panel Replacement: 4 단계, 이미지 2/2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Front Panel Replacement: 5 단계, 이미지 1/2 Blackberry Curve 8320 Front Panel Replacement: 5 단계, 이미지 2/2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Front Panel Replacement: 6 단계, 이미지 1/1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Front Panel Replacement: 7 단계, 이미지 1/1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Aiello
회원 가입일: 10/12/11
89 평판
안내서 5개 작성하였습니다
Cal Poly, Team 3-6, Regan Fall 2011 Cal Poly, Team 3-6, Regan Fall 2011 회원
CPSU-REGAN-F11S3G6
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 2,682
