주요 콘텐츠로 건너뛰기
Blackberry Curve 8330 Motherboard Replacement
필요한 것
  1. Blackberry Curve 8330 Motherboard Replacement, Remove Back Cover: 1 단계, 이미지 1/1
    • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
    • Hold the phone with the back side facing you.
    • Press down on the silver tab towards the bottom end of the phone.
    • Carefully lift up the back casing to reveal the battery.
  2. Blackberry Curve 8330 Motherboard Replacement, Remove Battery: 2 단계, 이미지 1/1
    • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
    • The phone should now look like this.
  3. Blackberry Curve 8330 Motherboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Remove the two top screws using a T5 Torx screwdriver.
  4. Blackberry Curve 8330 Motherboard Replacement: 4 단계, 이미지 1/2 Blackberry Curve 8330 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose.
    • The cover will now pull off easily.
  5. Blackberry Curve 8330 Motherboard Replacement: 5 단계, 이미지 1/2 Blackberry Curve 8330 Motherboard Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool to pry between the front and back cover.
    • Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
    • There are 5 securing clips on the front panel to disconnect.
    • Pry gently to prevent breaking the plastic clips when removing the front panel.
    • Once all the clips have been freed, the front cover will lift away from the phone.
  6. Blackberry Curve 8330 Motherboard Replacement: 6 단계, 이미지 1/1
    • Lift the flexible keypad away from the device. It should come off easily.
  7. Blackberry Curve 8330 Motherboard Replacement: 7 단계, 이미지 1/2 Blackberry Curve 8330 Motherboard Replacement: 7 단계, 이미지 2/2
    • Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing.
    • Lift the keyboard frame away from the device.
    • There may be a small amount of adhesive at the bottom of the frame that needs to be pulled away.
  8. Blackberry Curve 8330 Motherboard Replacement, LCD Panel: 8 단계, 이미지 1/2 Blackberry Curve 8330 Motherboard Replacement, LCD Panel: 8 단계, 이미지 2/2
    • Detach each side casing by pulling them off gently from the phone.
  9. Blackberry Curve 8330 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the back housing from the mother board.
  10. Blackberry Curve 8330 Motherboard Replacement: 10 단계, 이미지 1/1
    • Unhook the screen frame from the small tab at the top of the motherboard.
  11. Blackberry Curve 8330 Motherboard Replacement: 11 단계, 이미지 1/2 Blackberry Curve 8330 Motherboard Replacement: 11 단계, 이미지 2/2
    • Using a plastic opening tool, detach the connector on the LCD screen from the motherboard.
    • There may be some adhesive behind the LCD screen. If needed, pry the LCD screen away from the motherboard using the plastic opening tool.
    • Remove the LCD screen from the motherboard
  12. Blackberry Curve 8330 Motherboard Replacement, Motherboard: 12 단계, 이미지 1/1
    • Once the LCD screen is taken off, the motherboard is fully separated from the device.
    • The picture shown is the back side of the motherboard.
결론
Joshua Ramos
회원 가입일: 04/04/12
65 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-11, Forte Spring 2012 Cal Poly, Team 14-11, Forte Spring 2012 회원
CPSU-FORTE-S12S14G11
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 2,383
