주요 콘텐츠로 건너뛰기
Blackberry Curve 9300 Keyboard Replacement
필요한 것
  1. Blackberry Curve 9300 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Keyboard Replacement: 2 단계, 이미지 1/1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Keyboard Replacement: 3 단계, 이미지 1/1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Keyboard Replacement: 5 단계, 이미지 1/2 Blackberry Curve 9300 Keyboard Replacement: 5 단계, 이미지 2/2
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Keyboard Replacement: 6 단계, 이미지 1/1
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Keyboard Replacement: 7 단계, 이미지 1/1
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Keyboard Replacement: 8 단계, 이미지 1/1
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Keyboard Replacement: 9 단계, 이미지 1/1
    • Lift and remove the keyboard.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Rory Stothers
회원 가입일: 09/30/13
545 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-7, Forte Fall 2013 Cal Poly, Team 14-7, Forte Fall 2013 회원
CPSU-FORTE-F13S14G7
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 11
전체 시간: 4,666
