주요 콘텐츠로 건너뛰기
Blackberry Curve 9300 Speaker Replacement
필요한 것
  1. Blackberry Curve 9300 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Speaker Replacement: 2 단계, 이미지 1/1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Speaker Replacement: 3 단계, 이미지 1/1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Speaker Replacement, Keyboard: 4 단계, 이미지 1/1
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Speaker Replacement: 5 단계, 이미지 1/2 Blackberry Curve 9300 Speaker Replacement: 5 단계, 이미지 2/2
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Speaker Replacement: 6 단계, 이미지 1/1
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Speaker Replacement: 7 단계, 이미지 1/1
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Speaker Replacement: 8 단계, 이미지 1/1
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Speaker Replacement: 9 단계, 이미지 1/1
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Speaker Replacement, Speaker: 10 단계, 이미지 1/1
    • Locate and remove the two 5mm screws on top of the keyboard base with a T6 Torx screwdriver.
  11. Blackberry Curve 9300 Speaker Replacement: 11 단계, 이미지 1/1
    • Carefully pull keyboard base up and away from phone.
    • Disconnect keyboard base from phone completely.
  12. Blackberry Curve 9300 Speaker Replacement: 12 단계, 이미지 1/3 Blackberry Curve 9300 Speaker Replacement: 12 단계, 이미지 2/3 Blackberry Curve 9300 Speaker Replacement: 12 단계, 이미지 3/3
    • Remove the four 5mm screws on the top and bottom of phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Speaker Replacement: 13 단계, 이미지 1/2 Blackberry Curve 9300 Speaker Replacement: 13 단계, 이미지 2/2
    • Using a prying tool, find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • Prying tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Speaker Replacement: 14 단계, 이미지 1/2 Blackberry Curve 9300 Speaker Replacement: 14 단계, 이미지 2/2
    • From the back of the phone, use your finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Speaker Replacement: 15 단계, 이미지 1/1
    • Insert tweezers into the small holes on the top of the speaker.
  16. Blackberry Curve 9300 Speaker Replacement: 16 단계, 이미지 1/2 Blackberry Curve 9300 Speaker Replacement: 16 단계, 이미지 2/2
    • Lift the speaker up to remove the speaker from phone.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Alek Squires
회원 가입일: 09/30/13
431 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-7, Forte Fall 2013 Cal Poly, Team 14-7, Forte Fall 2013 회원
CPSU-FORTE-F13S14G7
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 4,134
