주요 콘텐츠로 건너뛰기
Blackberry Pearl 8100 SIM Card Replacement
  1. Blackberry Pearl 8100 SIM Card Replacement, Battery: 1 단계, 이미지 1/1
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. Blackberry Pearl 8100 SIM Card Replacement, SIM Card: 3 단계, 이미지 1/1
    • Slide the larger of the two metal casings upward (in the direction pointed to as “unlock”).
  3. Blackberry Pearl 8100 SIM Card Replacement: 4 단계, 이미지 1/1
    • Lift the metal casing.
    • Insert an SD Card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Robert Cronin
회원 가입일: 04/08/10
544 평판
안내서 6개 작성하였습니다
Cal Poly, Team 34-57, Forte Spring 2010 Cal Poly, Team 34-57, Forte Spring 2010 회원
CPSU-FORTE-S10S34G57
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 9
전체 시간: 9,237
