주요 콘텐츠로 건너뛰기
Blackberry RIM 7250 Side Button Replacement
필요한 것
  1. Blackberry RIM 7250 Side Button Replacement, Battery: 1 단계, 이미지 1/3 Blackberry RIM 7250 Side Button Replacement, Battery: 1 단계, 이미지 2/3 Blackberry RIM 7250 Side Button Replacement, Battery: 1 단계, 이미지 3/3
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Side Button Replacement: 2 단계, 이미지 1/3 Blackberry RIM 7250 Side Button Replacement: 2 단계, 이미지 2/3 Blackberry RIM 7250 Side Button Replacement: 2 단계, 이미지 3/3
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Side Button Replacement: 3 단계, 이미지 1/3 Blackberry RIM 7250 Side Button Replacement: 3 단계, 이미지 2/3 Blackberry RIM 7250 Side Button Replacement: 3 단계, 이미지 3/3
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Side Button Replacement, Back Housing: 4 단계, 이미지 1/2 Blackberry RIM 7250 Side Button Replacement, Back Housing: 4 단계, 이미지 2/2
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Side Button Replacement: 5 단계, 이미지 1/2 Blackberry RIM 7250 Side Button Replacement: 5 단계, 이미지 2/2
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Side Button Replacement: 6 단계, 이미지 1/1
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Side Button Replacement: 7 단계, 이미지 1/3 Blackberry RIM 7250 Side Button Replacement: 7 단계, 이미지 2/3 Blackberry RIM 7250 Side Button Replacement: 7 단계, 이미지 3/3
    • Grab the back housing from the bottom and lift the housing away from you.
  8. Blackberry RIM 7250 Side Button Replacement, Front Housing: 8 단계, 이미지 1/2 Blackberry RIM 7250 Side Button Replacement, Front Housing: 8 단계, 이미지 2/2
    • Place your thumb on the bottom rectangle and your index finger on the top rectangle.
    • Squeeze your fingers together to release the internals from the front housing.
  9. Blackberry RIM 7250 Side Button Replacement: 9 단계, 이미지 1/3 Blackberry RIM 7250 Side Button Replacement: 9 단계, 이미지 2/3 Blackberry RIM 7250 Side Button Replacement: 9 단계, 이미지 3/3
    • Pull the two pieces apart to separate the front housing from the internals.
  10. Blackberry RIM 7250 Side Button Replacement, Side Button: 10 단계, 이미지 1/2 Blackberry RIM 7250 Side Button Replacement, Side Button: 10 단계, 이미지 2/2
    • Remove the single 5 mm Torx T6 screw.
  11. Blackberry RIM 7250 Side Button Replacement: 11 단계, 이미지 1/3 Blackberry RIM 7250 Side Button Replacement: 11 단계, 이미지 2/3 Blackberry RIM 7250 Side Button Replacement: 11 단계, 이미지 3/3
    • Grab side button housing with your thumb and index finger.
    • Remove the side button housing from the internals.
  12. Blackberry RIM 7250 Side Button Replacement: 12 단계, 이미지 1/3 Blackberry RIM 7250 Side Button Replacement: 12 단계, 이미지 2/3 Blackberry RIM 7250 Side Button Replacement: 12 단계, 이미지 3/3
    • Hold the side button housing with one hand and hold the side button with the other.
    • Lift the side button from side button housing.
    • There will be a subtle click when the side button is detached from the side button housing.
결론
Noah Eckert
회원 가입일: 11/05/18
519 평판
안내서 5개 작성하였습니다
IUPUI, Team S2-G4, Baechle Fall 2018 IUPUI, Team S2-G4, Baechle Fall 2018 회원
IUPUI-BAECHLE-F18S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 156
