주요 콘텐츠로 건너뛰기
Blackberry Storm 9530 Battery Replacement
필요한 것
  1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: 1 단계, 이미지 1/3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: 1 단계, 이미지 2/3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: 1 단계, 이미지 3/3
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 Battery Replacement: 2 단계, 이미지 1/1
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
결론
melanie lim
회원 가입일: 04/22/14
607 평판
안내서 6개 작성하였습니다
Cal Poly, Team 9-16, Regan Spring 2014 Cal Poly, Team 9-16, Regan Spring 2014 회원
CPSU-REGAN-S14S9G16
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 1,632
