주요 콘텐츠로 건너뛰기
Blackberry Torch 9800 Logic Board Replacement
필요한 것
  1. Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: 1 단계, 이미지 1/2 Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: 1 단계, 이미지 2/2
    • Remove the back cover and the battery.
    • Unscrew the four screws using a T6 screwdriver.
    • Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Logic Board Replacement: 2 단계, 이미지 1/2 Blackberry Torch 9800 Logic Board Replacement: 2 단계, 이미지 2/2
    • Remove the side trim using the plastic opening tool.
    • Apply pressure to push the top side of the side trim towards the phone while pulling the bottom away from the phone to remove the side trim.
    • The side trim is fragile and easily fractured, so handful it with care.
  3. Blackberry Torch 9800 Logic Board Replacement: 3 단계, 이미지 1/3 Blackberry Torch 9800 Logic Board Replacement: 3 단계, 이미지 2/3 Blackberry Torch 9800 Logic Board Replacement: 3 단계, 이미지 3/3
    • Remove the two screws that have been revealed at the top of the device using the T6 screwdriver.
    • You should now be able to easily lift the back panel from the phone.
  4. Blackberry Torch 9800 Logic Board Replacement: 4 단계, 이미지 1/2 Blackberry Torch 9800 Logic Board Replacement: 4 단계, 이미지 2/2
    • Using your hands, carefully peel the three ribbon cable caps from the logic board.
  5. Blackberry Torch 9800 Logic Board Replacement: 5 단계, 이미지 1/2 Blackberry Torch 9800 Logic Board Replacement: 5 단계, 이미지 2/2
    • Lift logic board slightly. The logic board will remain attached to the phone by a small antenna wire.
    • Using your hands, carefully lift the clasp attached to the antenna wire straight upward away from the logic board.
    • Make sure not to disconnect the antenna wire from its clasp.
    • The logic board should now be completely separate from the phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Keegan Williams
회원 가입일: 02/19/16
216 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-5, Garvin Spring 2016 Ohio State, Team 1-5, Garvin Spring 2016 회원
OSU-GARVIN-S16S1G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 870
