주요 콘텐츠로 건너뛰기
Blackberry Torch 9800 Replacing rear camera
필요한 것
  1. Blackberry Torch 9800 Replacing rear camera, Replacing rear camera: 1 단계, 이미지 1/2 Blackberry Torch 9800 Replacing rear camera, Replacing rear camera: 1 단계, 이미지 2/2
    • Remove the back cover and the battery.
    • Remove the four exposed screws using a T7 screwdriver.
    • Warning: Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Replacing rear camera: 2 단계, 이미지 1/2 Blackberry Torch 9800 Replacing rear camera: 2 단계, 이미지 2/2
    • Remove the side trim using the plastic opening tool.
    • When loose, push the top backwards and the bottom forwards to remove.
  3. Blackberry Torch 9800 Replacing rear camera: 3 단계, 이미지 1/3 Blackberry Torch 9800 Replacing rear camera: 3 단계, 이미지 2/3 Blackberry Torch 9800 Replacing rear camera: 3 단계, 이미지 3/3
    • Two new screws have been exposed near the top of the back.
    • Remove the two screws using the T7 screwdriver.
    • Remove the back panel using the plastic opening tool.
  4. Blackberry Torch 9800 Replacing rear camera: 4 단계, 이미지 1/2 Blackberry Torch 9800 Replacing rear camera: 4 단계, 이미지 2/2
    • Carefully use flathead screwdriver to free camera sensor.
    • Wiggle on the right and left sides, not the top and bottom sides.
  5. Blackberry Torch 9800 Replacing rear camera: 5 단계, 이미지 1/1
    • To install the new camera sensor, place in slot. Reassemble phone by doing steps 1-3 in reverse order.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
0delete
회원 가입일: 02/16/16
183 평판
안내서 1개 작성함
Ohio State, Team 1-5, Garvin Spring 2016 Ohio State, Team 1-5, Garvin Spring 2016 회원
OSU-GARVIN-S16S1G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 284
