주요 콘텐츠로 건너뛰기
Blackberry Torch 9810 Cursor Key Replacement
필요한 것
  1. Blackberry Torch 9810 Cursor Key Replacement, Phone cover: 1 단계, 이미지 1/2 Blackberry Torch 9810 Cursor Key Replacement, Phone cover: 1 단계, 이미지 2/2
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Cursor Key Replacement, Battery: 2 단계, 이미지 1/1
    • Remove the battery
  3. Blackberry Torch 9810 Cursor Key Replacement, Remove screws: 3 단계, 이미지 1/1
    • Unscrew the four screws using the T6 screw driver.
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: 4 단계, 이미지 1/2 Blackberry Torch 9810 Cursor Key Replacement, Wiggle Wiggle: 4 단계, 이미지 2/2
    • Slide the screen up.
    • Remove front silver trim by using a plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Blackberry Torch 9810 Cursor Key Replacement, More screws that need to go: 5 단계, 이미지 1/1
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
  6. Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: 6 단계, 이미지 1/3 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: 6 단계, 이미지 2/3 Blackberry Torch 9810 Cursor Key Replacement, Remove the Back: 6 단계, 이미지 3/3
    • Use the plastic opening tools to remove the entire back off the phone.
  7. Blackberry Torch 9810 Cursor Key Replacement, Remove Ribbon Cables: 7 단계, 이미지 1/1
    • Remove the three ribbon cables and the antenna wire by hand.
    • The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
  8. Blackberry Torch 9810 Cursor Key Replacement, Remove Logic Board: 8 단계, 이미지 1/1
    • The logic board will easily pull straight out.
  9. Blackberry Torch 9810 Cursor Key Replacement, Remove Informational Sticker: 9 단계, 이미지 1/1
    • Remove the black sticker located above the logic board that contains the phone's serial number
  10. Blackberry Torch 9810 Cursor Key Replacement, Remove More Screws: 10 단계, 이미지 1/1
    • Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
  11. Blackberry Torch 9810 Cursor Key Replacement, Separate the phone: 11 단계, 이미지 1/1
    • Carefully separate the screen from the body.
    • Make sure to be extra careful with the ribbon!
  12. Blackberry Torch 9810 Cursor Key Replacement: 12 단계, 이미지 1/1
    • Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
    • They are on a black cover located on the bottom of the phone. The black cover will come off
  13. Blackberry Torch 9810 Cursor Key Replacement, Carefully Remove a Ribbion: 13 단계, 이미지 1/1
    • There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
  14. Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: 14 단계, 이미지 1/3 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: 14 단계, 이미지 2/3 Blackberry Torch 9810 Cursor Key Replacement, Cursor Key: 14 단계, 이미지 3/3
    • Push the cursor upwards and out of the socket.
    • Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jocelyn Adorno
회원 가입일: 10/16/14
296 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 17
전체 시간: 1,460
