주요 콘텐츠로 건너뛰기
Blackberry Torch 9810 Motherboard Replacement
필요한 것
  1. Blackberry Torch 9810 Motherboard Replacement, Phone cover: 1 단계, 이미지 1/2 Blackberry Torch 9810 Motherboard Replacement, Phone cover: 1 단계, 이미지 2/2
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Motherboard Replacement, Battery Removal: 2 단계, 이미지 1/1
    • Remove the battery
  3. Blackberry Torch 9810 Motherboard Replacement, Remove Screws: 3 단계, 이미지 1/1
    • Unscrew the four screws using the T6 screw driver
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Motherboard Replacement, Wiggle Wiggle: 4 단계, 이미지 1/2 Blackberry Torch 9810 Motherboard Replacement, Wiggle Wiggle: 4 단계, 이미지 2/2
    • Remove front silver trim by using plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Blackberry Torch 9810 Motherboard Replacement, More Screws: 5 단계, 이미지 1/1
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
  6. Blackberry Torch 9810 Motherboard Replacement, Remove the Back: 6 단계, 이미지 1/3 Blackberry Torch 9810 Motherboard Replacement, Remove the Back: 6 단계, 이미지 2/3 Blackberry Torch 9810 Motherboard Replacement, Remove the Back: 6 단계, 이미지 3/3
    • Use the plastic removal tool to remove the entire back cover.
  7. Blackberry Torch 9810 Motherboard Replacement, Small Antenna Wire: 7 단계, 이미지 1/1
    • Unplug the black antenna wire from the logic board.
  8. Blackberry Torch 9810 Motherboard Replacement, Remove Ribbon Cables: 8 단계, 이미지 1/2 Blackberry Torch 9810 Motherboard Replacement, Remove Ribbon Cables: 8 단계, 이미지 2/2
    • Peel off the three ribbon cables
    • They are orange and located on each side as well as on the top of the logic board
    • The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
  9. Blackberry Torch 9810 Motherboard Replacement, Logic Board: 9 단계, 이미지 1/1
    • Take out your logic board
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jocelyn Adorno
회원 가입일: 10/16/14
296 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 3,421
