필요한 것
Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
Peel off the three ribbon cables
The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
거의 끝나갑니다!
결론
다른 5명이 해당 안내서를 완성하였습니다.
