주요 콘텐츠로 건너뛰기
Blackberry Torch 9810 Rear Facing Camera Replacement
필요한 것
  1. Blackberry Torch 9810 Rear Facing Camera Replacement, Remove Cover: 1 단계, 이미지 1/2 Blackberry Torch 9810 Rear Facing Camera Replacement, Remove Cover: 1 단계, 이미지 2/2
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Rear Facing Camera Replacement, Remove Battery: 2 단계, 이미지 1/1
    • Remove the battery
    • Our phone did not come with a battery. This is where it would be located.
  3. Blackberry Torch 9810 Rear Facing Camera Replacement, Unscrew Screws: 3 단계, 이미지 1/2 Blackberry Torch 9810 Rear Facing Camera Replacement, Unscrew Screws: 3 단계, 이미지 2/2
    • Unscrew the four screws using the T6 screw driver
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Rear Facing Camera Replacement, Wiggle Wiggle: 4 단계, 이미지 1/2 Blackberry Torch 9810 Rear Facing Camera Replacement, Wiggle Wiggle: 4 단계, 이미지 2/2
    • Remove front silver trim by using plastic opening tools and wiggle it off.
    • (This is a little difficult to remove) Pull the bottom upward and pull the top downward.
  5. Blackberry Torch 9810 Rear Facing Camera Replacement, Smaller Screws That Must Go: 5 단계, 이미지 1/1
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
  6. Blackberry Torch 9810 Rear Facing Camera Replacement, Camera Sensor: 6 단계, 이미지 1/2 Blackberry Torch 9810 Rear Facing Camera Replacement, Camera Sensor: 6 단계, 이미지 2/2
    • Use the Phillip screw driver to wiggle the camera sensor out.
    • Carefully remove this
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jocelyn Adorno
회원 가입일: 10/16/14
296 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 12
전체 시간: 1,108
