필요한 것
Remove the four T5 screws.
Remove the single T5 screw from the bottom, next to the charging port.
Remove the screws from the sides.
Remove the screws holding the camera frame.
Pry out the sim car holder
Use a spudger or a utility knife to pry off the side bezels.
Use a plastic spudger to disconnect the flex connector and the antenna
Heat up this PCB with either iOpener or a heat gun on low temp (100-120 Celsius) to loosen the adhesive and pry it off from the side.
Remove the screws.
The last screw is under a tamper-proof sticker
Use plastic spudger or tweezers to disconnect the camera flex cable from the top
Disconnect the flex cable
Disconnect the antenna
Remove two J000 screws
Carefully pry up the camera. Heat from the glass side if necessary.
Unscrew and remove the camera assembly
Heat the light sensor from both sides to loosen the adhesive and gently pry them out of their sockets
Use some isopropyl alcohol if necessary to loosen the glue further on the audio jack
Grab it with strong tweezers and wiggle from side to side and upwards until it comes out. Heat further if necessary.
Lift it out and transfer to the new screen.
Gently peel the flex cable u p and transfer to the new assembly.
Heat up and pry up the bottom PCB (charging port) and transfer to the new screen.
다른 5명이 해당 안내서를 완성하였습니다.
