주요 콘텐츠로 건너뛰기
Blu Dash 5.0 Dual SIM Display Cable Replacement
필요한 것
  1. Blu Dash 5.0 Dual SIM Display Cable Replacement, Battery: 1 단계, 이미지 1/1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
  2. Blu Dash 5.0 Dual SIM Display Cable Replacement: 2 단계, 이미지 1/1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
  3. Blu Dash 5.0 Dual SIM Display Cable Replacement, Display Cable: 3 단계, 이미지 1/1
    • Using the PH00 Phillips head screwdriver unscrew the screws holding the panel down, making sure to keep track of the position of the screws.
    • The screw holes with the red circle around them hold screws with a 3.5 mm length.
    • The screw holes with the orange circle around them hold screws with a 2.5 mm length.
  4. Blu Dash 5.0 Dual SIM Display Cable Replacement: 4 단계, 이미지 1/2 Blu Dash 5.0 Dual SIM Display Cable Replacement: 4 단계, 이미지 2/2
    • Insert the plastic opening tool into a corner of the plastic panel and gently pry it away from the rest of the phone.
    • Do this for each corner until the panel pops up.
  5. Blu Dash 5.0 Dual SIM Display Cable Replacement: 5 단계, 이미지 1/3 Blu Dash 5.0 Dual SIM Display Cable Replacement: 5 단계, 이미지 2/3 Blu Dash 5.0 Dual SIM Display Cable Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Along the right side of the phone you will see a long black wire with 2 gold end pieces on the end. This is the display cable.
    • To disconnect the gold end pieces from the motherboard, take the tweezers and gently but firmly pull upwards. Do this for both ends and the wire will disconnect.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Dashaya Toney
회원 가입일: 10/27/14
876 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 4-7, Miles Fall 2014 UMass Dartmouth, Team 4-7, Miles Fall 2014 회원
UMASSD-MILES-F14S4G7
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 3,077
