소개
Blu Dash 5.0 Dual SIM Motherboard Replacement.
필요한 것
Find the small slot on the bottom left corner of the back panel.
Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
When the back panel is loose enough, use your fingers to remove it completely.
Using the PH00 Phillips head screwdriver unscrew the screws holding the panel down, making sure to keep track of the position of the screws.
The screw holes with the red circle around them hold screws with a 3.5 mm length.
The screw holes with the orange circle around them hold screws with a 2.5 mm length.
Along the right side of the phone you will see a long black wire with 2 gold end pieces on the end. This is the display cable.
To disconnect the gold end pieces from the motherboard, take the tweezers and gently but firmly pull upwards. Do this for both ends and the wire will disconnect.
Using the tweezers, lift the tabs where the cables are connected, this unlocks the cables. The cables will slide out of sockets easily when they are unlocked. Pull from wire using tweezers as pictured.
The red rectangles represent where the cable's are located.
The orange rectangles are where the cables pug into the ports. This is where you want to apply the tweezers.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 3개
i am having an issue with the display screen at first it fell from my mom when she pick it up there was a white line at the extreme top of the phone and after a while of use all of a sudden WHILE using it the white line started appearing all over in a horizontal fashion am afraid of touching anything on the mother board without knowing what it does the screen still works fine its just the horizontal lines all over and the colour quality kinda faded
keanu chin - 답글
I disabled the web viewer accidentally. I then realised that after I did that, the keypad locked as usual. After that the google talk option came to front of the screen, where I would need to log it. Its blocking the keyboard basically for I have no option to type my password in order to log in. How can I fix this problem.
Slot1 is messed up can you use slot 2. For simcard
