주요 콘텐츠로 건너뛰기
Blu Grand M Battery Replacement
필요한 것
  1. Blu Grand M Battery Replacement, Battery: 1 단계, 이미지 1/2 Blu Grand M Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Battery Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Battery Replacement: 3 단계, 이미지 1/3 Blu Grand M Battery Replacement: 3 단계, 이미지 2/3 Blu Grand M Battery Replacement: 3 단계, 이미지 3/3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Battery Replacement: 4 단계, 이미지 1/2 Blu Grand M Battery Replacement: 4 단계, 이미지 2/2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron Retzlaff
회원 가입일: 09/17/18
608 평판
안내서 5개 작성하였습니다
Washington State, Team S9-G2, Hope Fall 2018 Washington State, Team S9-G2, Hope Fall 2018 회원
WSU-HOPE-F18S9G2
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
i need to buy a replacement battery for this phone but i don’t know which one to get. please help
S_meals 562 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 2,374
