주요 콘텐츠로 건너뛰기
Blu Grand M Motherboard Replacement
필요한 것
  1. Blu Grand M Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Blu Grand M Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Motherboard Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Motherboard Replacement: 3 단계, 이미지 1/3 Blu Grand M Motherboard Replacement: 3 단계, 이미지 2/3 Blu Grand M Motherboard Replacement: 3 단계, 이미지 3/3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Motherboard Replacement: 4 단계, 이미지 1/2 Blu Grand M Motherboard Replacement: 4 단계, 이미지 2/2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Motherboard Replacement, Plastic Plate: 5 단계, 이미지 1/2 Blu Grand M Motherboard Replacement, Plastic Plate: 5 단계, 이미지 2/2
    • Remove the yellow plastic tape using a pair of tweezers.
  6. Blu Grand M Motherboard Replacement: 6 단계, 이미지 1/3 Blu Grand M Motherboard Replacement: 6 단계, 이미지 2/3 Blu Grand M Motherboard Replacement: 6 단계, 이미지 3/3
    • Use a Phillips #000 screwdriver to remove two black 4.0mm screws.
    • Use a Phillips #000 screwdriver to remove 2 silver 4.0mm screws
    • Remove the plastic cover along the top by tugging on it on the corner as shown.
  7. Blu Grand M Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 Blu Grand M Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Place a spudger or other tool underneath the black wire.
    • Lift up on the gold coaxial cable connector so it disconnects from the motherboard.
  8. Blu Grand M Motherboard Replacement: 8 단계, 이미지 1/3 Blu Grand M Motherboard Replacement: 8 단계, 이미지 2/3 Blu Grand M Motherboard Replacement: 8 단계, 이미지 3/3
    • Using the the narrow tip of a nylon spudger, open the two cable connector ports.
  9. Blu Grand M Motherboard Replacement: 9 단계, 이미지 1/2 Blu Grand M Motherboard Replacement: 9 단계, 이미지 2/2
    • Insert the spudger underneath the ribbon cable.
    • Pull the ribbon cable away from the gray connector.
    • The cable should pull away free from the gray connector without any resistance.
    • If you encounter resistance, check to see that the black cable connector port is open.
  10. Blu Grand M Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the four 4.0mm screws with a Philips #000 screwdriver.
  11. Blu Grand M Motherboard Replacement: 11 단계, 이미지 1/2 Blu Grand M Motherboard Replacement: 11 단계, 이미지 2/2
    • Lift the motherboard up and slightly away from the smartphone frame using the nylon tipped tweezers or other ESD safe tool.
    • The motherboard is still connected to the frame via a large black ribbon cable. Do not lift higher than this ribbon allows.
    • Flip the motherboard upside down to reveal the ribbon cable connector.
  12. Blu Grand M Motherboard Replacement: 12 단계, 이미지 1/2 Blu Grand M Motherboard Replacement: 12 단계, 이미지 2/2
    • A large black ribbon cable is connected to the underside of the motherboard.
    • Use the spudger to open the orange plastic ribbon connector.
  13. Blu Grand M Motherboard Replacement: 13 단계, 이미지 1/2 Blu Grand M Motherboard Replacement: 13 단계, 이미지 2/2
    • Insert the spudger into the folded ribbon cable loop.
    • Pull the ribbon cable away from the black plastic connector.
    • The ribbon cable should pull away from the black connector without any resistance.
  14. Blu Grand M Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove the motherboard with the nylon tweezers.
    • Place the motherboard on an electrostatic discharge (ESD) safe material.
결론
To reassemble your, follow these instructions in reverse order.
Note: The ribbon clamp connector, also known as a Zero Insertion Force (ZIF) connector, might be difficult to reinsert. Follow the reinstallation step at the end of this guide: 케이블 커넥터 인식 및 분리.
Liam Rollins
회원 가입일: 11/04/19
253 평판
안내서 2개 작성하였습니다
Idaho State University, Team S1-G2, Watkins Fall 2019 Idaho State University, Team S1-G2, Watkins Fall 2019 회원
ISU-WATKINS-F19S1G2
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 205
