주요 콘텐츠로 건너뛰기
Blu Grand M Speaker Replacement
필요한 것
  1. Blu Grand M Speaker Replacement, Battery: 1 단계, 이미지 1/2 Blu Grand M Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the two plastic plates with a plastic opening tool.
  2. Blu Grand M Speaker Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the 3mm screws. Be sure to do this for the top and bottom of the phone.
  3. Blu Grand M Speaker Replacement: 3 단계, 이미지 1/3 Blu Grand M Speaker Replacement: 3 단계, 이미지 2/3 Blu Grand M Speaker Replacement: 3 단계, 이미지 3/3
    • Remove SIM card tray with paperclip or SIM card tray removal tool.
    • Push down on the phone beside the camera and up on the backplate with your thumbs to remove the back plate. Remove adhesive if necessary.
  4. Blu Grand M Speaker Replacement: 4 단계, 이미지 1/2 Blu Grand M Speaker Replacement: 4 단계, 이미지 2/2
    • There is a patch of adhesive underneath the battery, which can make it difficult to remove.
    • Place the plastic opening tool in the highlighted indent, and push up on the battery to remove it.
  5. Blu Grand M Speaker Replacement, Speaker: 5 단계, 이미지 1/2 Blu Grand M Speaker Replacement, Speaker: 5 단계, 이미지 2/2
    • Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
    • Remove the 4.0mm screw with a Phillips #000 screwdriver.
    • Using the blue plastic opening tool, remove the exterior cover.
  6. Blu Grand M Speaker Replacement: 6 단계, 이미지 1/3 Blu Grand M Speaker Replacement: 6 단계, 이미지 2/3 Blu Grand M Speaker Replacement: 6 단계, 이미지 3/3
    • Use a Phillips #000 screwdriver to remove each of the four 1.5mm screws.
    • Use a Phillips #000 screwdriver to remove each of the three 3.0mm screws.
    • Use the plastic opening tool to remove the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cameron Retzlaff
회원 가입일: 09/17/18
608 평판
안내서 5개 작성하였습니다
Washington State, Team S9-G2, Hope Fall 2018 Washington State, Team S9-G2, Hope Fall 2018 회원
WSU-HOPE-F18S9G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 117
