주요 콘텐츠로 건너뛰기
Blu Grand M2 Power Button Replacement
필요한 것
  1. Blu Grand M2  Power Button Replacement, Power Button: 1 단계, 이미지 1/1
    • Using a T2 Torx Screwdriver, remove the two screws from the bottom edge of the phone.
  2. Blu Grand M2  Power Button Replacement: 2 단계, 이미지 1/2 Blu Grand M2  Power Button Replacement: 2 단계, 이미지 2/2
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious to not damage the phone display and or the inside components while using the pry tool and suction tool.
  3. Blu Grand M2  Power Button Replacement: 3 단계, 이미지 1/1
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
  4. Blu Grand M2  Power Button Replacement: 4 단계, 이미지 1/1
    • Place the new BLU Grand M2 power button in the socket.
결론
Alan Rodriguez
회원 가입일: 09/10/18
311 평판
안내서 2개 작성하였습니다
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018 회원
GCC-LUSTER-F18S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
Don’t forget to remove the SIM card
Jonathan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 342
