주요 콘텐츠로 건너뛰기
Blu L120 Loudspeaker Replacement
필요한 것
  1. Blu L120 Loudspeaker Replacement, Open the back panel: 1 단계, 이미지 1/3 Blu L120 Loudspeaker Replacement, Open the back panel: 1 단계, 이미지 2/3 Blu L120 Loudspeaker Replacement, Open the back panel: 1 단계, 이미지 3/3
    • Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
  2. Blu L120 Loudspeaker Replacement, Screw removal: 2 단계, 이미지 1/3 Blu L120 Loudspeaker Replacement, Screw removal: 2 단계, 이미지 2/3 Blu L120 Loudspeaker Replacement, Screw removal: 2 단계, 이미지 3/3
    • Remove these nine screws with a small philips screwdriver. They are all of the same size
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it.
    • *WARNING* by doing this you will void your manufacturer warranty.
  3. Blu L120 Loudspeaker Replacement, Rear panel removal: 3 단계, 이미지 1/3 Blu L120 Loudspeaker Replacement, Rear panel removal: 3 단계, 이미지 2/3 Blu L120 Loudspeaker Replacement, Rear panel removal: 3 단계, 이미지 3/3
    • Use the Spudger to gently separate the panel from the frame, starting from the bottom left corner.
    • Then work your way along the edges of the phone.
  4. Blu L120 Loudspeaker Replacement, Separate back panel and frame: 4 단계, 이미지 1/3 Blu L120 Loudspeaker Replacement, Separate back panel and frame: 4 단계, 이미지 2/3 Blu L120 Loudspeaker Replacement, Separate back panel and frame: 4 단계, 이미지 3/3
    • Continue using the spudger around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Loudspeaker Replacement, Speaker Removal: 5 단계, 이미지 1/2 Blu L120 Loudspeaker Replacement, Speaker Removal: 5 단계, 이미지 2/2
    • Use a pair of tweezers to grab the speaker assembly from the back of the panel and gently remove the it from the frame. (double sided tape is used to hold it together)
    • Install the new speaker, and follow the guide in reverse to reassemble the phone.
결론
Julio
회원 가입일: 10/25/14
695 평판
안내서 6개 작성하였습니다
Gateway, Team 1-5, Johnson Fall 2014 Gateway, Team 1-5, Johnson Fall 2014 회원
GCC-JOHNSON-F14S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
where can i get the Loud speaker
Shamar Houston - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 7
전체 시간: 279
