주요 콘텐츠로 건너뛰기
Blu L120 MicroSD Card Replacement
필요한 것
  1. Blu L120 MicroSD Card Replacement, Adding additional storage: 1 단계, 이미지 1/2 Blu L120 MicroSD Card Replacement, Adding additional storage: 1 단계, 이미지 2/2
    • Turn off the device, and remove the back cover. Start on the notch above the charging port and lift cover up and gently work around the phone until the back cover is off.
    • Remove the battery.
  2. Blu L120 MicroSD Card Replacement, Adding additional storage: 2 단계, 이미지 1/2 Blu L120 MicroSD Card Replacement, Adding additional storage: 2 단계, 이미지 2/2
    • Insert the media card into the phone. Maximum 32gb micro SD.
    • Reinstall the battery and back cover, and power on your device. Success............. you just added more storage to your phone.
결론
Julio
회원 가입일: 10/25/14
695 평판
안내서 6개 작성하였습니다
Gateway, Team 1-5, Johnson Fall 2014 Gateway, Team 1-5, Johnson Fall 2014 회원
GCC-JOHNSON-F14S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 192
