주요 콘텐츠로 건너뛰기
Blu L120 Rear Facing Camera Replacement
필요한 것
  1. Blu L120 Rear Facing Camera Replacement, Remove back panel: 1 단계, 이미지 1/3 Blu L120 Rear Facing Camera Replacement, Remove back panel: 1 단계, 이미지 2/3 Blu L120 Rear Facing Camera Replacement, Remove back panel: 1 단계, 이미지 3/3
    • Remove the cover by lifting the notch towards the bottom of the phone. Use your fingernail to lift it up.
  2. Blu L120 Rear Facing Camera Replacement, Screw Removal: 2 단계, 이미지 1/3 Blu L120 Rear Facing Camera Replacement, Screw Removal: 2 단계, 이미지 2/3 Blu L120 Rear Facing Camera Replacement, Screw Removal: 2 단계, 이미지 3/3
    • Remove these nine screws with a small phillips screwdriver. They are all the same size.
    • There is a small screw hidden under the warranty sticker. You may either remove or poke through it .
  3. Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: 3 단계, 이미지 1/3 Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: 3 단계, 이미지 2/3 Blu L120 Rear Facing Camera Replacement, Rear Panel  removal: 3 단계, 이미지 3/3
    • Use the pry tool to gently separate the panel from the frame, starting from the bottom left corner and continue along the edge of the phone.
    • *WARNING* by doing this, you will void the manufacturers warranty.
  4. Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: 4 단계, 이미지 1/3 Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: 4 단계, 이미지 2/3 Blu L120 Rear Facing Camera Replacement, Separate back panel from frame: 4 단계, 이미지 3/3
    • Continue using the pry tool around the back panel of the phone to separate both pieces.
    • Once you have gone around the entire frame, use both hands to pull it apart.
  5. Blu L120 Rear Facing Camera Replacement, Camera Removal: 5 단계, 이미지 1/3 Blu L120 Rear Facing Camera Replacement, Camera Removal: 5 단계, 이미지 2/3 Blu L120 Rear Facing Camera Replacement, Camera Removal: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the pry tool to disconnect the camera from the device.
    • Gently lift the camera up and use the tweezers to remove it from the phone.
    • Reinstall the camera. Then follow the guide in reverse to put the phone back together.
결론
Julio
회원 가입일: 10/25/14
695 평판
안내서 6개 작성하였습니다
Gateway, Team 1-5, Johnson Fall 2014 Gateway, Team 1-5, Johnson Fall 2014 회원
GCC-JOHNSON-F14S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 222
