소개
This is a relatively simple guide, and does not require any tools. Make sure you have a new battery ready to go before you begin.
Flip over your Studio 5.5 so the back is facing you.
Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
To reassemble your device, follow these instructions in reverse order, making sure you firmly press the back casing down so that it clicks in without bumps.
다른 3명이 해당 안내서를 완성하였습니다.
