주요 콘텐츠로 건너뛰기
Blu Studio 5.5 S Back Case Replacement
  1. Blu Studio 5.5 S Back Case Replacement, Back Casing: 1 단계, 이미지 1/1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Back Case Replacement, Applying Pressure: 2 단계, 이미지 1/3 Blu Studio 5.5 S Back Case Replacement, Applying Pressure: 2 단계, 이미지 2/3 Blu Studio 5.5 S Back Case Replacement, Applying Pressure: 2 단계, 이미지 3/3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
결론
To reassemble your device, insert the two tabs located at the bottom of the cover into the indents at the bottom of the phone. Then, press down on all sides of the phone until you hear it snap into place.
다른 한 분이 해당 안내서를 완성하였습니다.
Armen Garabedian
회원 가입일: 10/29/14
162 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014 회원
UMASSD-MILES-F14S4G8
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 17
전체 시간: 1,024
