주요 콘텐츠로 건너뛰기
Blu Studio 5.5 S Battery Replacement
  1. Blu Studio 5.5 S Battery Replacement, Back Casing: 1 단계, 이미지 1/1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Battery Replacement, Applying Pressure: 2 단계, 이미지 1/3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: 2 단계, 이미지 2/3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: 2 단계, 이미지 3/3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Battery Replacement, Battery: 3 단계, 이미지 1/3 Blu Studio 5.5 S Battery Replacement, Battery: 3 단계, 이미지 2/3 Blu Studio 5.5 S Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Cody Dyl
회원 가입일: 10/27/14
804 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014 회원
UMASSD-MILES-F14S4G8
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 6,151
