주요 콘텐츠로 건너뛰기
Blu Studio 5.5 S Front Facing Camera Replacement
필요한 것
  1. Blu Studio 5.5 S Front Facing Camera Replacement, Back Casing: 1 단계, 이미지 1/1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: 2 단계, 이미지 1/3 Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: 2 단계, 이미지 2/3 Blu Studio 5.5 S Front Facing Camera Replacement, Applying Pressure: 2 단계, 이미지 3/3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Front Facing Camera Replacement, Battery: 3 단계, 이미지 1/3 Blu Studio 5.5 S Front Facing Camera Replacement, Battery: 3 단계, 이미지 2/3 Blu Studio 5.5 S Front Facing Camera Replacement, Battery: 3 단계, 이미지 3/3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  4. Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: 4 단계, 이미지 1/3 Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: 4 단계, 이미지 2/3 Blu Studio 5.5 S Front Facing Camera Replacement, Midframe: 4 단계, 이미지 3/3
    • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
    • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  5. Blu Studio 5.5 S Front Facing Camera Replacement, Aesthetic Bottom Case: 5 단계, 이미지 1/1
    • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  6. Blu Studio 5.5 S Front Facing Camera Replacement: 6 단계, 이미지 1/3 Blu Studio 5.5 S Front Facing Camera Replacement: 6 단계, 이미지 2/3 Blu Studio 5.5 S Front Facing Camera Replacement: 6 단계, 이미지 3/3
    • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
    • Pick up the inner back case and flip it over.
  7. Blu Studio 5.5 S Front Facing Camera Replacement, Frontward Facing Camera: 7 단계, 이미지 1/2 Blu Studio 5.5 S Front Facing Camera Replacement, Frontward Facing Camera: 7 단계, 이미지 2/2
    • The frontward facing camera is located in the top left of the phone. It is connected to the motherboard by a ribbon connector, and a prong system.
    • Use a spudger to detach the front facing camera by flipping the orange tab on the top of the prong system.
    • Once the orange tab is up, pull out the orange ribbon wire.
  8. Blu Studio 5.5 S Front Facing Camera Replacement: 8 단계, 이미지 1/2 Blu Studio 5.5 S Front Facing Camera Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to pick up the ribbon wire, and lift. The frontward facing camera will follow suit.
결론
Cody Dyl
회원 가입일: 10/27/14
804 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014 회원
UMASSD-MILES-F14S4G8
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 1,560
